Sep 26, 2011 4:13 PM UTC
ACL test for environment variable
In my instance.acl script, I'm trying to test for the existence of an external variable and source the appropriate file depending on whether or not it's defined. This is how I'm trying to do it, but it doesn't seem to be working:
if ($main::ENV["XPS3_HOME"] != ") {
source $XPS3_HOME\XPSDocs\entities\commonStartup.acl
} else {
source $XPS_HOME\XPSDocs\entities\commonStartup.acl
That is, when "XPS3_HOME" is not defined, I'm getting an error during startup indicating that at line 2 it's trying to use an undefined variable. Anyone know the correct way of doing this test?
Dave
Siemens
    18-Opal
    Sep 26, 2011 4:15 PM UTC
    Hi Dave--
    Try defined($main::ENV["XPS3_HOME"]).
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Sep 26, 2011 4:16 PM UTC
    I think you'll want to use the defined function (this is off the cuff
    without testing)...
    Else if(!defined($main::ENV[XPS3_HOME])) {
    Source ...
    Sep 26, 2011 4:18 PM UTC
    Clay types faster than I do 🙂
    But to clarify now that I look at it, you'll want to put the defined
    statement first, so that it doesn't error before getting to the else
    if().
    Sep 26, 2011 4:19 PM UTC
    I'm not sure why I use this construction, but I assign the value of the
    environment variable to an ACL variable before using it. Maybe the problem
    you're having is what drove me there. Try:
    local yourvar = $main::ENV["XPS3_HOME"]
    if ($yourvar !=") ...
    Sep 26, 2011 5:49 PM UTC
    Hi Clay,
    That looks like exactly what I need. So, I changed the ACL to:
    if(!defined($main::ENV['XPS3_HOME'])) {
    } else {
    It still drops into the second "source" and reports the undefined variable.
    Doesn't seem like this should be that hard! Any other suggestions?
    Dave
    Sep 26, 2011 5:58 PM UTC
    Well, this seems to work:
    global xpshome = $main::ENV["XPS3_HOME"]
    if($xpshome == ") {
    } else {
    source $xpshome\XPSDocs\entities\commonStartup.acl
    Unless someone knows of a less-confusing method, I'll go with this.
    Thanks, Paul!
    Dave
    On Mon, Sep 26, 2011 at 1:49 PM, Hintz, David <-> wrote:
    > Hi Clay,
    > } else {
    DRY...
    local xps_home = $main::ENV['XPS_HOME']; # or global..., if not in a function
    if (defined($main::ENV['XPS3_HOME'])) { xps_home = $main::ENV['XPS3_HOME']; }
    source $xps_home\XPSDocs\entities\commonStartup.acl;
    -Brandon Smiley Happy
    > Dave
    > -----Original Message-----
    > From: Clay Helberg [
    > --Clay
    > Clay Helberg
    > Senior Consultant
    > TerraXML
    > From: Hintz, David [
    > Thanks
    > Dave
    > Siemens
    > -----End Original Message-----
    Sep 26, 2011 6:14 PM UTC
    Thanks, Brandon. That looks pretty much like what I came up with.
    18-Opal
    Sep 26, 2011 6:31 PM UTC
    Hi Dave--
    After taking a closer look at your code, I think the problem is in your
    source statement rather than in the test. I tried the following code:
    response("XPS3 not found");
    } else {
    response("XPS3 was found");
    It gives the correct response under both conditions, i.e. if environment
    variable "XPS3_HOME" is defined, it says it's found, otherwise it says
    not found.
    But in your code, you are concatenating $XPS3_HOME, which is not the
    same as $main::ENV['XPS3_HOME']. Try changing your code to something
    like this:
    source $main::ENV['XPS_HOME']\XPSDocs\entities\commonStartup.acl
    } else {
    source $main::ENV['XPS3_HOME']\XPSDocs\entities\commonStartup.acl
    Clay Helberg
    Senior Consultant
    TerraXML
    Sep 27, 2011 8:48 AM UTC
    Reading your messages, I suddenly doubt.
    We use an environment variable SIGMA witch is a network path, or does not exist.
    In our scripts, we just use the very simple code :
    If ($SIGMA=="){
    do_something;
    }else{
    source $SIGMA/myscript.acl
    Does it work only because we are not inside a function (we are in a script directly called by instance.acl)
    Furthermore, defined($SIGMA) return 0, even if the environment variable has a value.
    We use Epic 52, maybe we'll have bad surprise with newer versions...
    Yves Deniard
    MBDA
    1 avenue Réaumur
    92358 Le Plessis-Robinson cedex
    France
    tél.:01.71.54.27.39
    yves.deniard@mbda-systems-com
    -----Message d'origine-----
    De : Clay Helberg [
    } else {
    It gives the correct response under both conditions, i.e. if environment variable "XPS3_HOME" is defined, it says it's found, otherwise it says not found.
    But in your code, you are concatenating $XPS3_HOME, which is not the same as $main::ENV['XPS3_HOME']. Try changing your code to something like this:
    } else {
    Clay Helberg
    Senior Consultant
    TerraXML
