ACL to clear the Windows clipboard
Whacky. But I needed to do this an stumbled on a way how to do it. Maybe
it's useful to someone else.
# The following may have dependencies on sgmlselection, selectionsvc,
pastepreserve,
# and/or any other settings related to buffers, copying, pasting, etc.
# Create a temporary buffer and make it current.
set paste=junk
# write to that buffer. You could select and copy something if
# wherever you that is easy. Or you can just write a line of
# throw-away text to the buffer. Type "help insert_buffer" for
# a complete description of the syntax of this command.
insert_buffer("any string of text",0,"junk")
# Set the default buffer back to current.
set paste=default
I had to tell you now because it's Friday and my weekend will permanently
purge MY buffer and I won't remember I wanted to tell you come Monday ...
Paul Nagai
    delete_buffer -all;
    clears Arbortext paste buffers -- but not apparently the Windows clipboard--so don't know if this helps.
    - Lou Argyres
    CEB / Continuing Education of the Bar | ceb.com
    In Reply to Paul Nagai:
    pastepreserve,
    set paste=junk
    set paste=default
    Paul Nagai
    naglists1-VisitorAuthor
    Hi Lou,
    The code I provided does clear the Windows clipboard ... with some
    assumptions about the various settings that relate to cut/copy/paste/buffer
    management. Turns out I also delete_buffer -all after clearing the Windows
    clipboard for the thing I'm doing, but it wasn't necessary/related to
    clearing the Windows clipboard so I didn't mention it.
    Thanks, though. It's probably good to have available in this thread for
    future me and anyone else diving into the buffers.
