Mar 15, 2016 11:22 PM UTC
ACL to restrict attribute values for user selection
I want to be able to restrict an attribute's enumerated values presented for user selection without modifying the XML schema - can this be done with ACL?
    18-Opal
    Mar 16, 2016 2:51 PM UTC
    Hi Andrew--
    Sure, you can do this. Use the "modify_tag" doc callback to fix up the attribute value list, something like this:
    function mt_callback(doc, oid, win, op) {
      if (op == 1) { return 0; }
      # get doc ID
      local dlgdoc = _xmldlg::getDialogDocument(win);
      local tagname = oid_name(oid);
      # get list of attrs with enumerated values (comboboxes in modify attrs dlg)
      local attrs[], a;
      oid_xpath_nodeset(oid_root(dlgdoc),attrs,"//combobox");
      # find the attr we want to modify
      local values[], v, alias, attr;
      for (a in attrs) {
        attr = attrs[a];
        attrname = oid_attr(attr,"id");
        if (//attrname is attribute to be modified//) {
            # hide unwanted values
            local items[], i;
            oid_find_children(attr, items, "listitem");
            for (i in items) {
                local label = oid_attr(items[i],"label");
                if (//label should be removed//) {
                     oid_delete(items[i]);
    Then, somewhere in your initialization code, make sure you add the callback:
    doc_add_callback(0, "modify_tag", "mt_callback");
    Replace the bits between double slashes //..// with proper tests and this will give you better control of the attribute values without having to modify the schema.
    --Clay
    abolton1-VisitorAuthor
    Mar 16, 2016 3:04 PM UTC
    Thanks Clay for the fast response (and documented code!).  I will try this and get back
