18-Opal
April 19, 2013
adding a comment to ditamap
If you go to insert, comment (alt, ctrl, m) . YBryon
    18-Opal
    April 19, 2013
    Hi Bryon--
    You can do this with a pretty simple doc callback. Callbacks let you
    respond to particular events. In this case, the insertion of a comment
    tag is the event you want to respond to. Put this code somewhere in your
    init ACL file:
    function insert_tag_after_callback(doc, tagname, oid, op) {
    if (op==1) { return 0; }
    if (tagname == "_comment") {
    goto_oid(oid);
    insert("[" . username() . "]: ");
    doc_add_callback(0, "insert_tag_after", "insert_tag_after_callback");
    Now, when someone inserts a comment, it will be prepended with their
    username, something like this:
    with the caret positioned so the user can start typing comment content
    after the colon.
    See the Help Center documentation for doc_add_callback for details on
    how callbacks work and how to define callback functions.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    bfriesen18-OpalAuthor
    18-Opal
    April 19, 2013
    Thanks again Clay. I find it hard to use the help when you dont know the proper terminology to search on. I will do some reading.
    Bryon
    Hey, Clay
    Looks like there may have been changes to call-back functions in AE after ver 5.3.
    I got following error when I tried your code as is in my AE 5.3 M110:
    Wrong number of arguments to insert_tag_after_callback(): 3 passed, 4 expected
    (at line 93 of file "C:\Program Files\Arbortext\Editor\packages\main\_docev.acl")
    I checked AE 5.3 help for insert_tag_after callback type [help 148] and saw it had this function prototype:
    funcname (doc, tagname, op)
    So I changed the function to have 3 parameters (no "oid") as follows and it now works
    as advertised:
    function insert_tag_after_callback(doc, tagname, op) {
    Thanks for this,
    --Jack
    18-Opal
    April 23, 2013
    Thanks for the clarification, Jack. My projects tend to use current
    releases of Arbortext, so that's usually what I test against, and
    sometimes I forget that there are folks out there still using older
    versions.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Lafayette, CO 80027
    Thanks Clay.I added the date_time() into the insert statement.
    insert("[".username.()." ".time_date(est)."]:");
    Do you have any advice on ridding the time from the output?
    Thanks again,
    Chris
    18-Opal
    April 25, 2013
    According to the documentation, all the fields of the time_date() function are fixed width, so you should just be able to take a fixed substring, like this:
    insert("[".username.()." ". substr(time_date(est),1,10) ."]:");
    Clay Helberg
    Senior Consultant
    TerraXML
    Lafayette, CO 80027
