bfriesen
18-Opal
Feb 21, 2018 5:12 PM UTC
Adding a language in styler question
When adding a language to styler, on the language tab under generated text, you need to select the target language. Lets say I want toe add es-CL (Spanish (Chile). How do I set the Document Language mapping.
Is document language set to es (Spanish) and the Language to Use is set to the region CL? Or should it be the other way around.
Bryon
