Adding to event log
In the documentation for the doc_add_callback() function, callback type
"completeness_check ", it says that "This callback can add reports to
the event log". Any idea how that can be done? I've got some java
classes that perform validations (that can't be done with the schema or
schematron) that I'd like to run and have their results appended to the
report that's shown after a completeness check.
Brian Jensen
bjensen@bluelid.com
    18-Opal
    October 16, 2012
    Hi Brian--
    Take a look at the _eventlog package in the Arbortext packages/tools
    folder, you can probably find something there you can use to add new
    entries to the event log.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    BrianJ1-VisitorAuthor
    Clay,
    I'll take a look at that package and see what I can use. Thanks for your
    help!
    Brian Jensen
    bjensen@bluelid.com
