May 5, 2011 10:16 AM UTC
AEditor 5.4 - .cache file - Guide?
We recently upgraded Epic 5.1 to Editor 5.4 for our application.
We noticed that when we edit an xml file, this generate a <fileName>.xml.cache file.
Important: to edit our xml files, we use a website which downloads the xml file on the local computer. At the moment, we can not assure that this .cache file is generate by AEditor. It may be generated by the website.
Does someone know if this file is generated by AEditor 5.4 ? If so, we are wondering about the use of this file. Where can we find some help about this ?
Thanks.
