bfriesen
18-Opal
Aug 7, 2020 5:48 PM UTC
Any one using named user licenses for editor or isodraw?
Just wondering if they work through a remote desktop connection. Currently we have mostly node locked licenses and cannot open the programs through a remote session.
Bryon
bfriesen
bfriesenAnswer
18-Opal
Sep 8, 2020 11:57 AM UTC
We have received a response from PTC regarding the counted/uncounted. The said they would correct the topic to say node locked and floating. It is not possible to have a node locked counted =1.
Bryon
Aug 9, 2020 11:47 PM UTC
I believe current versions of Isodraw use Flexnet licensing. The node-locked Flexnet licenses will not work for remote desktop sessions. Registered user and Concurrent (floating) user licenses should work just fine with remote desktop.
BTW, the reason for that is with a node-locked license PTC has to avoid the problem where multiple copies of the licensed application can be run at the same time using remote desktop as a workaround. That behaviour "cheats" the system to the ultimate detriment of all PTC customers.
Aug 10, 2020 8:39 AM UTC
It's worth looking at the following article that may help CS102518 as there are different type of locked licenses.
Regards
Shaun
bfriesen
bfriesen18-OpalAuthor
18-Opal
Aug 10, 2020 12:29 PM UTC
Shaun is the link correct? That article is for How to create a Query Builder report that shows the groups of which a user is a member in Windchill. Did not see anything about locked licenses in there.
Bryon
Aug 12, 2020 12:09 AM UTC
I believe Shaun intended to link here: https://www.ptc.com/en/support/article/CS102518
The real way to solve the issue is through the use of the Flexnet licensing server. This means you remove the license file from the machine(s) and install the licenses on the license server. Each remote desktop session will then check out a license from the license server.
