May 19, 2010 9:59 PM UTC
apostrophe/single-quote is curly (wrong) not straight in PE/PDFDirect PDFs in ArialMT
I hate special characters.
Does anyone know how to control the presentation of apostrophes (decimal 39)
in PDFs generated on Publishing Engine by PDF Direct (not Distiller) in the
Arial font? I am getting a curly apostrophe in the Arial MT font. (I doubt
Arial MT is actually the problem, but I mention it just because.) I can use
charent.cf to map the output of ' to a good old fashioned
straight-quote / non-curly-apostrophe ... decimal 39. But this doesn't fix
the ' character itself ...
Paul Nagai
    naglists1-VisitorAuthor
    May 19, 2010 10:07 PM UTC
    I should say my charent.cf solution works in theory. I haven't rolled it out
    to my Publishing Engine environment where I have, possibly in a different
    authoring environment than the one I'm currently bumping into ' problems,
    had charent.cf solutions fail in the content pipeline due to multiple
    parsings ...
    With Styler, peservices=off, Print Composer, my Stylersheet, no profiling
    selected, and DLM engaged (there's one leg of a pipeline), I was able to
    control the PDF's content. (Ok, just checked, it works with profiling, too
    ... maybe I'll be ok in prod ... assuming I can convince my authors its
    acceptable to change every instance of ' to ' ... yeah, that would be a
    fun conversation 😉
    18-Opal
    May 20, 2010 1:12 AM UTC
    Hi Paul-
    If you searched the archives at all on this, you probably found some old
    posts of mine on the subject. I did eventually figure out what the
    problem was. There's a setting in your pipeline that originates in
    epicGenerator.ent that controls this.
    If you're still using 5.3 or earlier. In my 5.3 version, the relevant
    entry from $EPIC/composer/epicGenerator.ent looks like this:
    <parameter id="epicGenerator.convertSingleQuote"&lt;br"/>name="convertSingleQuote" type="boolean" required="no">
    <label>Convert Single Quote to Right Curly Quote</label>
    <documentation>This parameter determines whether single quote ('
    #39)
    should be converted into ’ (#8217) before
    sent to pipeline.
    Default is true.
    </documentation>
    </parameter>
    So you might get a win on this by customizing your pdf.ccf (or your
    May 20, 2010 1:54 PM UTC
    I looked at SPR 1646473, and there are a lot of complicated technical
    notes (including a mentino of the pipeline stuff Clay discusses), but
    one other thing I found was a mention of set
    composedcharactersubstitution (see help topic 7557) that might be of
    help.
    As Clay mentions, in 5.4, we changed the behavior (effectively setting
    composedcharactersubstitution to off instead of on as it was in 5.3).
    paul
    May 24, 2010 12:59 PM UTC
    Paul,
    I came across the same issue. Even though we had the ' entity in use, we would get the curly apostrophe published. Then I found the "set composedcharactersubstitution = no"command and entered it into our initialization files. The issue went away.
    Hope this helps.
    Bob
    May 24, 2010 11:46 PM UTC
    Thanks, Bob. Am working with support. Dynamic Link Manager is involved in my
    particular instance of the curly apos.
    On Mon, May 24, 2010 at 5:59 AM, Bob Spangenburg <
    -> wrote:
    > Paul,
    > composedcharactersubstitution = no" command and entered it into our
    > Hope this helps.
    > Bob
    Jun 4, 2010 8:54 PM UTC
    Support has opened SPR 1988168 for a future 5.3 service release. The problem
    does not exist in 5.4. They have, in the mean time, provided me with
    customized comp_pdf.acl and pdf.ccf files. I have not had a chance to test
    them yet and likely won't until after PTC/User (Fire UP!) but will let you
    know how that goes when it goes.
