Nov 18, 2010 5:19 PM UTC
Arbortext 5.3 stripping forward slash from empty elements
Arbortext is stripping the / from empty elements when I load them, e.g.
<header:metadata-item name="create-date" value="20100920"/"> becomes
<header:metadata-item name="create-date" value="20100920">
so the document isn't even well formed any more. However, Arbortext still gives it a clean bill of health (no completeness errors). Can someone please point me at the setting in Prefs that fixes this - none of my colleagues is having this issue.
Thanks.
    Nov 18, 2010 5:29 PM UTC
    The / at the end of an empty element is an XML characteristic. The lack of one on empty elements is an SGML characteristic. Are you sure that your doctype is not being compiled as SGML?
    Nov 18, 2010 6:12 PM UTC
    Or is it using the alternate presentation of empty? If it is reporting the
    XML is correct than this:
    most likely became:
    <header:metadata-item name="create-date"&lt;br"/>value="20100920"></header:metadata-item>
    They are equivalent content.
    ..dan
    Nov 19, 2010 2:48 PM UTC
    In Reply to John Hanratty:
    Are you by any chance using 5.3 M010? We had the same problem when we tested that particular version, and opened a service call. The problem is resolved in 5.3 M030 and later versions.
    Meghan Fiero
    Thanks.
    Nov 19, 2010 3:23 PM UTC
    In Reply to Meghan Fiero:
    Yes, I am using 5.3 M010. What a nasty little bug! I will get the latest maintenance release and test to see if it fixes the issue for me too. Thanks for the info!
    Meghan Fiero
    Thanks.
    Nov 19, 2010 3:36 PM UTC
    That's why we have maintenance releases J
    Nov 19, 2010 6:03 PM UTC
    Do you know whether there are any issues with M050?
    In Reply to Peter Li:
    Nov 20, 2010 6:54 PM UTC
    Presumably, yes, there are issues with M050 as the 5.3 branch is up to M210 now... so, 21 maintenance releases on top of the original release.
    If you wanted more specific information about the issues/fixes you should check the "product release notes" shipped with M210 to see what changed in each maintenance release.
    -G
    Nov 22, 2010 10:38 AM UTC
    These email alerts to available updates are quite handy also!
    http://www.ptc.com/appserver/cs/subscriptions/subscriptions.jsp?p=tab_summary
    Cheers
    Chris
    Chris Western
    www.tformat.com
