Arbortext 5.4 and Java 7 issues
- 4 replies
- 4519 views
- Translate All
Hello all,
Are there Java / Arbortext configuration updates required in order to run Arbortext 5.4 with Java 7? After doing an upgrade from Java 6.30 to 7.5 I’m getting the follow errors starting up Arbortext 5.4.
“Internal error: dl_load failed for C:\Program Files\Java\jre7\bin\client\jvm.dll”
That error is followed by:
“[A12281] Cannot create a Java virtual machine from “C:\Program Files\Java\jre7\bin\client\jvm.dll (-1).”
Will Arbortext 5.4 run with Java 7? If so, how?
Thanks!
>> Randy
Randy McGarvey
Operations Software Architect
General Code ♦ 800-836-8834
Thanks!
>> Randy
Randy McGarvey
