Jun 23, 2016 7:39 PM UTC
Arbortext 5.4, trying to compose to PDF, error?
So Tech Writer is trying to compose Arbortext file to PDF and getting this error.
The following should be true: (-1 <=vl && lvl < maxlevel - 1) in the file ../src/fchange.cpp:988
What does this mean?  I'm not very familiar Arbortext, so not sure if there is a more specific log error to look for?  Other similar files are composing just fine?
    Jul 11, 2016 12:55 PM UTC
    fchange.cpp is involved in change tracking.
    (-1 <= lvl && lvl <= maxlevel - 1) is stating that the change level is not within the defined parameters.
    are you nesting change levels or do you have a change tag missing?
    Jul 11, 2016 3:11 PM UTC
    Are all of you change tracking regions defined? (Areas where the change bars appear)
