Feb 6, 2019 12:27 PM UTC
Arbortext 6.1 custom application issue when upgraded to ATX 7.0
We are using arbortext 6.1, we are using custom application containing different schemas and it is referenced from a server....application works fine in arbortext 6.1 but the same same application is not working properly in arbortext 7.0 getting unknown tags and attribute errors saying its not defined in xsd file, which is really strange.
structure of the application is each schema folder is different under doctypes for ex - doctypes->diagonostic, doctypes->description etc so each schema has its own xsd files, schema template and catalog file, dcf file etc.
need help on this asap!
please let me know the root cause of this issue
Awaiting your reply
bfriesen
18-Opal
Feb 6, 2019 2:57 PM UTC
At some point they switch from dita 1.2 to 1.3 in 7.0 M60. This made our application not happy. See case
CS263588.
Bryon
arupkundu1-VisitorAuthor
Feb 6, 2019 4:58 PM UTC
i dont have access to see the cases, could you please elaborate the issue
bfriesen
18-Opal
Feb 6, 2019 5:03 PM UTC
The title is Upgrade to 7.0 M060 open document almost everything is out of context Arbortext Styer 7.0 M060
Resolution:
Bryon
