Dec 14, 2016 8:25 AM UTC
Arbortext 6.1 don't run on WinXP SP3
after installation Arbortext 6.1 don't run on WinXP SP3,
it is show error message "The point of entrance isn't found in the subroutine GetDateFormatEx in the DLL library KERNEL32.dll".
Do you have any ideas?
Dec 18, 2016 1:21 PM UTC
I note that according to MSDN, the GetDateTimeEx API method is only available since Windows Vista. Arbortext 6.1 is not officially supported on Windows XP, therefore I don't think you can use Arbortext 6.1 with Windows XP.
Dec 15, 2016 1:22 PM UTC
Please send your issue to technical support by using PTC's "Case Logger": https://support.ptc.com/appserver/cs/case/case_logger.jsp
vnikonov1-VisitorAuthor
Dec 18, 2016 2:35 PM UTC
Thank you very much for your answer!
