Jan 30, 2023 12:48 PM UTC
Arbortext 8.2.0.0 and Arbortext Layout Developer 12.2.0.0 have released!
Key Highlights: Editor/Styler/Publishing Engine
  • Support for DITA 2.0
    • Initial support for DITA 2.0 (based on OASIS pre-release)
  • Enhancements to the Queued Transactions dialog box in Editor
  • Arbortext publishing worker in Windchill can send content to publish in a payload
  • Requires Java 17
  • Creo View is updated to version 9.0
  • Responsive Web Frameset for Styler
    • New frameset provided with completely new CSS and layout to provide a responsive Web output which reacts to viewport size changes
    • Uses the same chunking code as default web output but provides new navigation, toolbars and linking
Key Highlights Arbortext Layout Developer/Layout Editor
  • Workspaces
    • Save and restore customisations through the ALD interface including toolbars, keyboard layouts, menus and libraries
    • Run custom scripting when workspaces are loaded and unloaded
    • Include additional custom system files
  • Interface updates
    • New and improved dialogs for Frame, Paragraph and Style properties
    • Features reorganised to be more accessible and in a single dialog
    • Previously hidden features now exposed through UI
  • Debugger enhancements
    • Interactive page view including custom information displayed in pop-ups for frames, blocks, tables, lines and styles
    • Code completion now includes function tags, declared functions and any JSDoc from within functions and from external definitions files
plutsky15-MoonstoneAuthor
Feb 17, 2023 3:14 PM UTC
Arbortext Editor, Styler, and Publishing Engine 8.2.0.1 have Released!
This release supports the ability to run Editor or Styler 8.1.x.x and 8.2.0.1 on the same system.
It also contains bug fixes.
8.2.0.0 will no longer be available for download.
PTC recommends that customers who have previously downloaded 8.2.0.0 should uninstall 8.2.0.0 and move to 8.2.0.1.
