Dec 19, 2024 4:08 PM UTC
Arbortext 8.2.3 PDF Labeling Convention incorrect.
I am having issues when a PDF is created, the labeling is incorrect and out of order on table of contents, tables and figures. Please see sample file for example. Has anyone co
bfriesen
18-Opal
Dec 19, 2024 5:54 PM UTC
Is this the using the ootb stylesheet or have you customized it already?
Bryon
Dec 19, 2024 7:36 PM UTC
They were actually customized for us by PTC, have not modified it since. Have been using the same stylesheet since 5.3 and is now experiencing issues in 8.2.3.
bfriesen
18-Opal
Dec 19, 2024 7:43 PM UTC
That is a huge jump. The stylesheet will have been modified by editor when you first opened it to bring it up to speed with the version of software. But there will probably be issues like you are seeing. You will probably need to get PTC or Partner (GSPL, EAC, etc) to take a look at the stylesheet and fix anything that broke during the upgrade. We ran into the same issue.
Bryon
