Jul 31, 2014 11:35 AM UTC
Arbortext AAD 4.4 M080 Print Services Problem with TOC
I am using the 4.4 M080 print services and I noticed that on page 1 of a Data Module the Table of Contents lists the paras 1, 2, 3, 3.2, 3.2 and then stops. There are a couple of figures after para 3.2 and then the text content resumes. There should be entries for 4 through 5.4.3 since the data module contains more content. Does anyone have a quick fix for this?
Greg
Jul 31, 2014 12:43 PM UTC
In each case where the TOC stops, a figure is inserted into the printed publication.
Jul 31, 2014 1:33 PM UTC
I vaguely remember having, probaly, similar issue with earlier 4.4 M0x0. Are those figures "normal" or landscape (inside a foldout element)?
Jul 31, 2014 1:48 PM UTC
The sequence is a portrait figure followed by two foldouts... Then more levelledPara elements
