Arbortext ACL initiation errors
I got error when starting up Arbortext.
Arbortext Editor Response:
[A18115] Error in initialization file: C:\Program Files\PTC\Arbortext Editor\adapters\com.ptc.prowt.arbortext\init\WindchillAdapterInitializer.js,
(A12281) Cannot create a Java virtual machine from
“\\....\jre7\bin\Client\jvm.dll” (-1).
James
    18-Opal
    August 24, 2012
    Hi Sindy--
    Have you modified your javavmmemory setting in one of your other init
    files? Sometimes if you try to set it too high it will cause the JVM to
    fail to start, which would give this error.
    Maybe try starting up a "plain vanilla" Editor session, with no
    customizations, and verify that it works correctly. If it does, then you
    know it's something to do with your customizations, so start checking
    for anything that affects JVM startup, like javavmmemory, javavmpath,
    javavmargs, etc.
    If even a plain vanilla Editor with no customizations won't start, then
    check any java-related environment variables, e.g. APTJAVAVMARGS,
    JAVA_HOME or JAVA_OPTS.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    No, I have not modified the javavmmemory setting.
    Clay,
    We changed our settings back to java 6.1 and everything seems to work fine. Perhaps Arbortext is not compatible with Java 7.1
    Sindy
    Sindy:
    Just went through this issue ourselves. Arbortext Editor 5.4 is only certified for JRE 1.6.0_34 as of M140.
    John Sillari
    Chief Technologist
    Dayton T. Brown, Inc.
    We encountered this earlier in the year, but since it was isolated to a
    single user (probably someone proactive about running Java updates), I
    temporarily used the javavmpath setting to set to a local copy of an older
    jvm.dll within an acl in custom/init
    set javavmpath="C:\ptc\jvm.dll"
    I've been meaning to get around to finding the "preferred" approach to
    setting this, so I'm wondering what everyone else has done.
    I'm sure there's some easier way to do this (eg: JAVA_HOME env var), but I
    wasn't sure at the time off the top of my head. Hopefully this is
    something I can configure into our patches, since we use the automatic
    CUSTOM patch deployment within Arbortext.
    keith
