Arbortext and Win 7
We currently are using 5.3. Corp is upgrading to 64bit Win7 in near future. Will 5.3/5.4/ or the new 6.0 be supported on 64 bit?
Thanks.
    Hi George,
    In the latest Software Compatibility Matrix, Editor 5.4 M80 is compatible with 64bit.
    Editor 5.3 should work but is not certified.
    Editor 6.0 is likely to support 64bit but the SCM is not published yet.
    Cheers
    Pete
    Simonsoft UK Limited
    GEORGER1-VisitorAuthor
    Thank you for the info !
    Is Arbortext Editor 6.0 work with PE 5.4?
    Sudheendra
    Hi Sudheendra,
    Publishing Engine (PE) always needs to be at least the same or later release/datecode as the Arbortext Editor clients using PE.
    So for example if your Arbortext Editor clients are 6.0 M020 you need to have at least Publishing Engine 6.0 M020.
    Regards
    Sirko
    Hi Sirkko,
    Thanks you very much.
    Now, We need to decide on weather to migrate to 6.0 or not.
    Sudheendra
