Jan 17, 2011 8:39 AM UTC
Arbortext and Windchill Integration
Could anybody help me doing Arbortext and windchill integration using
Object->Connect
I used content manager guide to configure the PTC server. No Success.
Thanks in advance,
Manisha.
    Jan 17, 2011 10:06 AM UTC
    Hello Manisha,
    You should create file
    <arbortext_install_dir>\adapters\com.ptc.prowt.arbortext\siteprefs.xml.
    Best way is to create a copy from file "siteprefs_template.xml" is localted
    in same dir.
    Next you should define Windchill server name. Open siteprefs.xml file, find
    element <parametername>HostList</parametername> and his child element
    <parametervalue>.
    Define server name in format: Name|Windchill connection URL, like in
    example below:
    <parametervalue>r70|">http://r70.windchill.ru/Windchill</parametervalue>
    </parameter>
    r70 - what I see in server field,
