Sep 16, 2016 10:20 AM UTC
Arbortext - DTD problem?
We have just installed Arbortext Editor v7, our first installation.  When we try and  open a 1.8 DM, we get a "dtd did not compile message", with the following explaination.
  1. Dtgen.exe Parser Error: While parsing file C:\Users\martin.eggleston2\Desktop\AECMA1-8\dm\DOCTYPES\descript.dtd: Cannot find file called C:\Program Files\PTC\Arbortext Editor/markit/ispudir. Is it in the currently active directory (err:1 line:18  pos:1064) Compile failed - rc=32
Can anyone help?
Please realise that we are NOT expert users…
    Sep 18, 2016 12:03 AM UTC
    In addition to Ray's advice, you might also want to consider contacting whoever supplied the S1000D doctypes to you. They may need to perform updates for compliance with 7.0 (or may already have a 7.0-compliant release for you). It doesn't appear you are using the PTC S1000D modules (which only support 4.0 and 4.1 of the spec).
    Sep 16, 2016 2:01 PM UTC
    You need to check with PTC as the directory for Markit in 7.0 is different than 6.1. In 6.1 there are two files ispudir, and ispudirp in the 6.1 market folder that do not appear in the 7.0 Markit. You need to put in a case for this, it could be an issue or a process change.
    ray
    Sep 19, 2016 8:26 AM UTC
    We seem to (somehow or other) moved on from this problem onto another problem.  The DTD will still not compile and we now get the following error message:
    Warning: Could not locate DTD entity '%COMPS'
       Public Identifier: '-//AECMA1-8/DTD/Comps.ent'
       System Identifier: '(none)'
       No entry was found for the above public identifier
       in any of these files:
          W:\cECS\Epoch\Test DTD\AECMA1-8\catalog
          C:\Program Files\PTC\Arbortext Editor\doctypes\catalog
    While parsing file W:\cECS\Epoch\Test DTD\AECMA1-8\DTD\descript.dtd:
    Unknown parameter entity name (AECMA) used in reference.
    If name is spelled correctly check that the entity declaration in the DTD
    contains a PERO (e.g. %) symbol followed by a space
    (err:623  line:73  pos:3874)
    HELP!
    Sep 26, 2016 6:33 AM UTC
    Thank you for all your support.
    It seems that we need an SGML plug-in so have requested this through our support contract.
    Aug 19, 2019 5:39 PM UTC
    I'm facing the same problem, what SGML plugin was it, and where did you get it?
    Thanks!
