Arbortext editor 6.0 M140 32- bit setup
Hello Everyone ,
Does any one have Arbortext Editor 6.0 M140 32- bit setup file
AlexiaAnswer
Only currently supported versions of the software will be available for download from the main PTC Support site.
Where possible we would only recommend customers use the most recent versions of the software, but we do realise that sometimes an older release is required.
I would also like to make you aware, that Arbortext Editor 6.0 was not supported for the latest Windows versions, and you may run in to issues that we cannot support.
Please raise a Technical Support case with PTC support and we will be able to make Arbortext Editor 6.0 M140 available for you to download.
We would not expect other Users to make PTC software available on any site other than legitimately via the PTC Technical Support process.
I would ask you to also mark this as 'Accept as Solution'.
Kind Regards
Alexia
Alexia15-MoonstoneAnswer
Kind Regards
Alexia
Thank you for the information, I will check with PTC technical Support.
Community Moderator
October 10, 2024
Hello @AK_10359491,
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi Vnamboodheri,
Still, I didn't get the setup file.
Hello @AK_10359491
Please refer to my response on 7th October 2024 and raise a request to PTC Technical Support - this is the only way you will get the Editor installation files.
You do currently have a Support Contract which allows you to raise cases with PTC.
Best wishes
Alexia
