Mar 14, 2014 3:29 PM UTC
ArborText Editor 6.1 - Export to HTML
I'm evaluating ArborText 6.1 (Editor with Styler) with a 14-day trial license.
Can it export to HTML? I don't see that option anywhere.
Thanks!
Chris
    TimPhelpsAnswer
    Mar 14, 2014 5:12 PM UTC
    Does your style sheet allow HTML composition?
    From Arbortext select Styler > Edit Style Sheet
    Select File > Stylesheet Properties
    Is HTML File check box checked?
    Alternatively, check the .dcf file associated with your dtd or schema.
    Does it allow HTML output?
    Content like
    <Composition>
    <Compose type="htmlfile"></Compose>
    <Compose type="pdf"></Compose>
    </Composition>
    Mar 14, 2014 3:57 PM UTC
    You can publish to HTML. File > Publish > HTML file....
    There is also an menu pick for File > Save As HTML...
    (This latter usage is not as good as publishing).
    Mar 14, 2014 4:40 PM UTC
    I see the HTML options if I start from a new document.
    However, if I open an existing file (It's an xml file with ArborText comments, so I can only assume that it was created with ArborText), I don't have the HTML options for save-as (or publish).
    Does that mean I can't save this particular document as HTML (or is there an add-on I can get that will do this)?
    TimPhelps12-AmethystAnswer
    Content like
    <Composition>
    </Composition>
