Jun 6, 2016 12:15 PM UTC
Arbortext Editor 6.1 randomly adds unwanted newlines, aka carriage returns, througout the text
Arbortext Editor 6.1 adds unwanted newlines aka Carriage Returns througout the text. They are not visible within the editor but are visible in any text editor. This is an extremely annoying behaviour. Is there any way to turn this "feature" off. For anyone that runs scripts over the markup this is a pain because this breaks search patterns.
Example: The newlines break at odd places, for example there's a cr after <xref:
in accordance with sub-paragraph <xref
linkend="myid"></xref>.
Jun 8, 2016 3:12 PM UTC
Ok per your suggestion if the outputrecordlength is set to infinity all newlines are removed from the xml file. If you already have a file full of newlines, setting this and then re-opening and saving the file will remove all of the unwanted newlines aka carriage returns.
In the Editor:
Tools/Preferences
Click on the dialog's Advanced... button
scroll down the list to outputrecordlength
select it, click on the edit button
set it to infinity, it is 72 by default in my installation of the editor
Close
OK
Jun 6, 2016 2:21 PM UTC
In Arbortext Editor there is writenobreakattag variable.
Set this to a value of "on".
In Arbortext Editor one can set the outputrecordlength.
This may help also.
See Arbortext Editor's Help Center for further details.
Jun 6, 2016 3:32 PM UTC
Thank you Tim, I'll give that a try, hopefully that will cure the problem.
In the meantime I also wrote a little Omnimark script to remove the unwanted returns:
;omnimark -sb om_newline_cleaner.om input.txt -of output.txt -log error.txt
cross-translate
;PURPOSE
;The purpose of this script is to remove newlines from PTC Arbortext 6.1 text.
;Script Author Greg MacKenzie
find (">" white-space* "<") => ThrowAway; finds newlines, tabs, and other spaces between tags
output "><" ;removes newlines from in between tag brackets
find "%n" => ThrowAway; all remaining newlines should be in the middle of text or markup, bears checking though
output " " ;adds a space where the newline was
