Feb 19, 2016 2:03 PM UTC
Arbortext Editor and Arbortext Engine Compartibility
  Plan to migrate the below  Documentum  Components for
new wisdom 2016 project.
  1. WebTop    -  6.7 SP2   to  6.8  version
  2. Content Server     -  6.7 SP1   to  D7.2 SP2 version
  3. DFS  - 6.7 SP1   to  D7.2 SP2 version
  4. Windows OS      -  2008  to  2012
Can you please check Arbortext Editor and Arbortext Engine  current version (6.0M060 ) or new version (6.1 or if any) Compatibility  with  WebTop and content server  above mention
new version and provide the details on this.
Thanks for helping  on this .
Regards
Siva
    TimPhelpsAnswer
    Feb 23, 2016 1:25 PM UTC
    Documentum 7 is not supported
    Documentum 6.8 is supported on Windows 7 and Windows 8
    JDK 7 U21 is supported
    See http://support.ptc.com/WCMS/files/169431/en/Arbortext-Software-Compatibility-Matrices-6.1M070.pdf
    See pages 11-13
    Feb 20, 2016 2:25 PM UTC
    Arbortext Editor 6.0 M140 is compatible with Documentum WDK 6.5, 6.6, 6.7, 6.7 SP1 and 6.7 SP2 with Apache Tomcat
    It is compatible on Window 7 and 8, but not with IE10 or higher
    Arbortext Editor 6.1 F000 - M070 support Documentum WDK. 6.1 M080 does not.
    Be sure to let the community know if this answers your question
    spalani1-VisitorAuthor
    Feb 22, 2016 10:25 AM UTC
    Thanks for your response.
    I need some more clarifications on this.
    What is the latest version of Arbortext Editor and Arbortext Engine ?
    If have a latest version then following version can be compatible.please provide the Yes/No and provide the compatible with comment against on below :
    1. WebTop    -  6.8  version
    2. Content Server     -  D7.2 SP2 version
    3. DFS  -    D7.2 SP2 version
    4. Windows OS  server    -  windows 2012
    and Is Arbortext Editor certified with Java 8 & IE 9+? and Is Arbortext Engine certified with 2008 or 2012?
    Our wsidom application currently using version 6.0M060.It can be  compatible with below  version.  please provide the Yes/No and provide the compatible with comment against on below :
    Please provide the details on this?
    Regards
    Siva
    Feb 22, 2016 12:17 PM UTC
    The latest version of Arbortext Editor is 7.0 M010.
    This information is available at the PTC support site.
    http://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm
    and
    Compatability info is available at
    http://support.ptc.com/WCMS/files/168977/en/Arbortext-Software-Compatibility-Matrices-7.0-M010-11.1-M010.pdf
    The 7.0 release of Arbortext Products does not support Documentum.
    So "No" is the answer to your questions.
