Arbortext Editor auto-defines entities
Adepters:
When a user copies and pastes content from one document to another and the target document does not have definitions for entity references in the copied content, Arbortext Editor auto-defines these entities and inserts them in the internal subset. How do I stop this behavior. We want Arbortext to immediately report an error for undefined entities and turn off context rules.
Dave Hintz
Siemens
    18-Opal
    July 27, 2012
    Hi Dave--
    You might be able to use a "paste" document callback to check the paste
    buffer for entity references, and check each one to see if it is defined
    for the target document; if not, you can abort the paste with a warning
    message. See the help center topic for "doc_add_callback" for details on
    how to set up this kind of callback.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
