Jun 20, 2011 8:57 PM UTC
Arbortext Editor Create PDF Modifies Graphics Paths
I have a rather large xml document with several graphics in it. The graphics are all stored as entities and then referenced by their entity name in the document. When I do a "create PDF" on the document, Arbortext systematically goes through and hard codes the file path for each graphic into the xml document before creating the PDF. Is there a setting somehwere that stops this behavior?
