Arbortext Editor error message
Hello everyone!!
Today I'm facing a new problem, I was trying to open a document in
Arbortext and it shows me an Alert/Error message, it says: "editor.exe:
segment violation(signal 11)" Then, when I click the OK button,
Arbortext closes. Does anybody know what does this mean?!
As always I really appreciate your help and support.
Regards!
Paulette Zorrilla
    I'm sure everyone on this list has seen one of those errors before! They mean something went wrong in a really bad way inside Arbortext. You can perform a process of elimination to determine what is causing the crash (eg. remove all images from your document, remove all tables, chop the documen down, and so on, until you find what the problem was).
    If you consistently encounter the error condition then you should probably file a support call with PTC anyway. They may end up asking you to do an "appsave" so the programmers can reproduce the error and fix it in a future patch release. This assumes you have an active maintenance agreement with PTC.
    Cheers,
    Gareth
    Of course, for segment 11 errors, there's always the "Have you tried turning it off and back on again?" solution.
    I'm pretty sure we have Signal 11's as "expected normal operation" at this
    point in our user manual, with a reminder to our users to save early, save
    often.
    keith
    pzorrilla1-VisitorAuthor
    Woow!! As Gareth says I think it was related with one of my lines inside de document, specifically in my Instruction. Now the Alert message doesn't appears.
    Has anyone seen this message before and do you know how to raise the value?
    Capacity limit IDCAP exceeded. The number of points to add is 72;
    the program has already used 299952 points and the declared maximum
    value is 300000
    Clear as mud? I have NO idea what any of that meant, but hopefully it's
    helpful.
    Sindy,
    IDCAP is the maximum number of IDs in a document (I think). The reference capacity (ISO 8879:1986) is 35000. The IDCAP in my setup has been changed to 2000000.
    In your catalog find the default SGML Declaration. My SGML declaration looks like this (Custom for JCALS; [ArbortextInstallPath]\doctypes\catalog has the Arbortext default declaration):
    SGMLDECL "custom/entities/jcals.sgml.dcl"
    Open the file specified and change the value of IDCAP:
    Here is an annotated copy of the SGML declaration that I got from the AF-TMSS (AF-Technical Manuals Standards and Specifications). The notes are quite handy:
    !SGML "ISO 8879:1986"
    -- JCALS SGML declaration --
    CHARSET
    BASESET "ISO 646-1983//CHARSET International Reference Version
    (IRV)//ESC 2/5 4/0"
    DESCSET 0 9 UNUSED
    9 2 9
    11 2 UNUSED
    13 1 13
    14 18 UNUSED
    32 95 32
    127 1 UNUSED
    BASESET "ISO Registration Number 100//CHARSET
    ECMA-94 Right Part of Latin Alphabet Nr. 1//ESC 2/13 4/1"
    DESCSET 128 32 UNUSED
    160 5 32
    165 1 UNUSED
    166 88 38
    254 1 127
    255 1 UNUSED
    CAPACITY SGMLREF -- Default to Reference Capacity Set --
    -- unless specified here --
    TOTALCAP 3500000 -- TOTAL of individual capacity points --
    ENTCAP 100000 -- ENTities defined --
    ENTCHCAP 500000 -- CHaracters of ENTity text --
    GRPCAP 2000000 -- Tokens at any level in a content model --
    ATTCAP 1000000 -- ATTributes defined --
    IDCAP 2000000 -- ID attributes specified --
    IDREFCAP 3500000 -- IDREF attributes specified --
    AVGRPCAP 100000 -- tokens defined in an Attribute Value name GRouP --
    Reference capacities are as follows:
    TOTALCAP 35000 TOTAL of individual capacity points
    ENTCAP 70000 ENTities defined
    ENTCHCAP 35000 CHaracters of ENTity text
    ELEMCAP 35000 ELEMents defined
    GRPCAP 35000 Tokens at any level in a content model
    EXGRPCAP 35000 EXclusions or inclusions defined
    EXNMCAP 35000 NaMes in an EXclusion or inclusion
    ATTCAP 35000 ATTributes defined
    ATTCHCAP 35000 CHaracters of default ATTribute value
    AVGRPCAP 35000 tokens defined in an Attribute Value name GRouP
    NOTCAP 35000 NOTations defined
    NOTCHCAP 35000 CHaracters in a NOTation
    IDCAP 35000 ID attributes specified
    IDREFCAP 35000 IDREF attributes specified
    MAPCAP 35000 short reference MAPs declared
    LKSETCAP 35000 link types or LinK SETs defined
    LKNMCAP 35000 document types or elements in a LinK declaration
    Thanks Andy.
    As has already been pointed out, this is an old SGML restriction. Early in
    the days of Adept and smaller computers, the capacities contained in the
    SGML Declaration were very critical. Now, they tend to be annoying messages
    that really have no impact (that I have been able to discern) on your
    files.
    Andy is right that you can go into your default declaration and change the
    value.
    I did find an old (from 1997 when XML was the 'new kid on the block')
    comparison. One paragraph discusses the declaration use for XML. Under the
    CAPACITIES header is a note that 'capacities are not restricted in XML'.
    Check this page
    We get that ID capacity error occasionally with some of our files, the larger ones, obviously. We have some ACL that runs automagically and puts IDs on a lot of potential link targets, including table rows. This "error" has never caused any problems, probably since, like Lynn says, capacities are not restricted in XML.
