Nov 10, 2015 4:07 PM UTC
Arbortext Editor: How to show the entity codes?
we use the entity list in the Arbortext Editor 6.1 to insert some special unicode-entities.
As you can see we also can insert the unicode "‌":
Unfortunately if we insert this entity the user cannot see the inserted entity:
Only if we open the selected text as xml source we can see this entity code:
Therefore we would like to ask the community if there is a possibility to visualize entities in the document.
We thought about a button, where we could toggle the view, where the user can activate the entity view or not. Is this possible? Or is there any other option to show the entity code for the users in the normal tag-view of the Arbortext Editor?
Thank you in advance for your help.
