Apr 1, 2011 5:38 AM UTC
Arbortext Editor, Offsite Installations, and slow performance
Hello, I'd like to pick the lobes of those of you who have had
experience with supporting offsite (particularly offshore) Arbortext
installations.
Basically, I am supporting a set of authors in India, who up until 3
weeks ago, were using a custom directory on one of their servers that I
kept r-synced with a custom directory on a US server. We are using
Editor 5.3 M040 on WinXP SP3 PCs, most are new (dual-core, 2G RAM or
better). We are working with an in-house developed DTD and FOSI.
We have recently gotten them access to our test server with the custom
directory we use to test changes before migrating to production, which
is a server located in the US.
What I am experiencing is starting the India Editor can take 1-4 minutes
on startup when loading with the US server custom directory. If the
India Editor is pointing to the India server custom directory, Startup
time is less than a minute.
Where things get really odd is once I get the India Editor open when
reading from the US server custom file, opening the first XML file takes
in the area of 7-11 minutes to open. Once I get that first document
open, I can open any document of the same doctype in 8-15 seconds. It
acts as if it's caching the doctype, and taking a ungodly amount of time
doing it.
I tried this both with the author logged in while I watched over webex,
and I tried while logged in myself (being an admin, I was trying to
eliminate possible access issues). This made no difference on
performance. I also tried loading a document both connected and not
connected to the PE server, this also made no difference in performance.
If I open an XML document authored with a different doctype, that first
document will also take 7-11 minutes, and 8-15 seconds for each
subsequent document.
I also took the custom directory down to the bare bones, no ACL, no
customizations of any kind except for the DTD, FOSI, and DCF. Catalog
file with one entry for this doctype. No discernable change in
performance.
The other oddity is if I point my APTCUSTOM at the custom directory on
the India server and start my US Editor, I have no performance issues.
Now, I have noticed, if I VPN into my network and try to start
Arbortext, it will spend 20 minutes initializing unless I take one
particular entry out of my catalog file. This entry points to a catalog
file on a UNIX share accessed through a Samba mount point. I also tried
this with the India Editors and it made no difference.
I also opened several other apps, opened files on both US and India
servers, but Arbortext seems to be the only one getting hung up trying
to startup and open documents. I was able to access all files for the
documents and the custom dir from the command line, so I don't see any
access issues.
Basically, I'm tired, cranky, and just looking for clues that might
point me in the right direction to troubleshoot this. What have other
folks been seeing? Are there any particular problems with, for
instance, samba shares? system-funcs in FOSIs? It just seems like
there's something I am missing here, but i've been benchmarking and
chasing this for a week, and it's starting to become a blur.
Also, does anyone know of a way to run Editor in a "debug" mode? I
found the atitrace.exe file in the bin with the epic.exe, but starting
it up provides almost no information (basically startup and quit). Is
there a flag, or setting, or environment variable that I can adjust to
turn up the logging? I'm really stumped here, and I have a requirement
to get these authors running on our test server.
Any and every idea and suggestion is greatly appreciated...
-Jason A. Buss
    Apr 2, 2011 2:33 AM UTC
    Ummm, my sentiments exactly. If Arbortext performance becomes
    unreasonably slow because of mapped drives or shortcuts to network
    drives on your desktop, Arbortext has a bug; Simple as that.
    Apr 4, 2011 12:19 PM UTC
    We have similar issues here in the states, but usually less lag time. Our virtual servers are in another state. For us, the first load lag of the day is 3-8 minutes...then is ok every time after that. Our small off-site office sounds more like your India lag times, although they have problems with everything, not just Arbortext, so they seem to add in the usual office netword connectivity issues.
    The only thing PTC mentioned to us was turning off applications we weren't using by renaming or deleting the directories under "application" (DITA and SMA). That did not help -- and the directories get reloaded on each maintenance fix install.
    There is certainly no way we could un-map all our drives! Sometimes I personally will have C-Z all mapped.
    Since we use the PE, I have not had any luck with copying the custom doc type locally - it still bops off and reads the PE...while we twiddle our thumbs...
    John T. Jarrett
    In Reply to Jason Buss:
    installations.
    doing it.
    performance.
    access issues.
    -Jason A. Buss
    John T. Jarrett, CDT
    BAE Systems | Arbortext w/PE version 5.4 | LOGSA XSL-FO v 1.7
    Apr 4, 2011 3:54 PM UTC
    Ok, so in the interest of brevity, I did fire up Arbortext with the
    debug=3.27, opened a doc (almost 20 minutes) and started analyzing the
    log.
    I have located two places where it seems like the Editor gets hung up.
    The first:
    [pid=4204] - 19:46:03.338 - _sslist 1497 [6] if (!
    _sslist::use_in_uselist(use,uselist))
    [pid=4204] - 19:46:03.338 - _sslist 1311 [7] if
    (== use USE_ANY)
    [pid=4204] - 19:46:03.338 - _sslist 1313 [7]
    local ause[]
    [pid=4204] - 19:46:03.338 - _sslist 1314 [7]
    local (= 'nuse' split(uselist,ause,","))
    [pid=4204] - 19:46:03.338 - _sslist 1315 [7]
    local 'u'
    [pid=4204] - 19:46:03.338 - _sslist 1316 [7] for
    (in u ause[])
    [pid=4204] - 19:46:03.338 - _sslist 1317 [8] if
    (== use ause[u])
    (in u ause[])
    (== use ause[u])
    (in u ause[])
    (== use ause[u])
    (in u ause[])
    (== use ause[u])
    (in u ause[])
    (== use ause[u])
    [pid=4204] - 19:46:03.338 - _sslist 1318 [9]
    return 1
    [pid=4204] - 19:46:03.338 - _sslist 1516 [6] return
    1
    [pid=4204] - 19:46:03.338 - _sslist 1585 [4] return
    cachedmsg
    [pid=4204] - 19:55:19.755 - _docev 770 [3]
    _dochook::doc_create_housekeeping(doc)
    [pid=4204] - 19:55:19.755 - _dochook 694 [4] (=
    Adoc_options[doc] ")
    [pid=4204] - 19:55:19.755 - _docev 773 [3] local
    Amonitor[]
    And the second:
    [pid=4204] - 20:11:55.524 - _docev 773 [3] local
    Amonitor[]
    [pid=4204] - 20:11:55.524 - _docev 774 [3] if
    doc_callback_list(h::opHookMonitor,h::hookCreate,Amonitor)
    [pid=4204] - 20:11:55.524 - _dochook 498 [4] local (=
    'key' doc_option_key(doc,option))
    [pid=4204] - 20:11:55.524 - _dochook 476 [5] local (=
    'key' (. (. doc ":") tolower(option)))
    [pid=4204] - 20:11:55.524 - _dochook 483 [5] return
    (|| (== doc h::opHookMonitor) doc_valid(doc)) ? key : "
    [pid=4204] - 20:11:55.524 - _dochook 500 [4] if (&& (!=
    key ") (in key Adoc_options[]))
    [pid=4204] - 20:11:55.524 - _dochook 502 [5] return
    split(Adoc_options[key],A,",")
    [pid=4204] - 20:11:55.524 - _docev 776 [4]
    _docev::doc_create_notify_all(Amonitor,doc)
    [pid=4204] - 20:11:55.524 - _docev 754 [5] local
    'j' 'func'
    [pid=4204] - 20:11:55.524 - _docev 755 [5] for (<=
    j count(Acb)) (= j 1) j++
    [pid=4204] - 20:11:55.524 - _docev 758 [6] (=
    func Acb[j])
    [pid=4204] - 20:11:55.524 - _docev 759 [6] if
    defined((. func "()"))
    [pid=4204] - 20:11:55.524 - _docev 761 [7]
    catch((*func)(doc))
    [pid=4204] - 20:11:55.524 - loaddita 122 [8] if
    doc_type_dita(newdoc)
    [pid=4204] - 20:11:55.524 - _docev 765 [5] return 1
    [pid=4204] - 20:11:55.524 - _docev 782 [3] return
    [pid=4204] - 20:20:42.393 - _winev 59 [3]
    Apr 4, 2011 4:22 PM UTC
    With multiple remote offices using Arbortext Editor, we found it best to
    put the compiled document types on a network drive located in each office.
    More work for us, but a much faster user experience as the editor is
    constantly checking and validating with the DTD.
    Larry Porter
    Underwriters Laboratories Inc.
    333 Pfingsten Road
    Northbrook, IL 60062
    Direct Line: 847-664-3966
    Cell Phone: 847-875-2771
    Apr 4, 2011 6:08 PM UTC
    The issue with zip files was related to a JDK bug - http://bugs.sun.com/bugdatabase/view_bug.do;?bug_id=5050516
    We use Resource Manager heavily and, due to this bug, it sometimes got slowed down by zip files that it encountered. The workaround was to move the zips or turn off windows zip integration.
    The response from Arbortext on 7/29/2009:
    There is a known issue with the java method that builds the directory listing. It can cause an entire .zip file to be parsed if the Windows Zip integration is active (which it is in XP and later by default).
    It is your choice whether to perform the easy solution (remove zip files from the Desktop) or the more permenant solution (turn off Windows Zip integration).
    To disable the Windows Zip functionality you can run the following at a Windows Command Prompt:
    regsvr32 /u %windir%\system32\zipfldr.dll
    -Mark
    Apr 4, 2011 6:25 PM UTC
    Hi Mark,
    Thanks for the details. Did you attempt upgrading to a patched version of
    the JDK?
    Apr 4, 2011 11:42 PM UTC
    So I ran some tests and did NOT find the problem.
    I used Editor 5.3 m110 and Java 1.6.0 (build 1.6.0-b105) although I forget
    which Java Editor uses for what ... 5.3 m110's own internal Java version
    un-noted by me ... the version above is what's reported by Java > About Java
    in Control Panel. I can't quite tell whether this is before or after the
    patch reported in the bug linked to in Mark's last e-mail ... the version
    formatting is different. I'm on Windows XP SP3 with 2GB RAM on a Dell
    Latitude E6400.
    Detailed results (should be readable if in monotype typeface). Time is m:ss.
    Network Shortcuts/zips No
    shortcuts/zips.
    Local Custom Editor First Start 1:14 2:16
    Local Custom Doc First Open 0:14 0:11
    Local Custom Editor Second Start 0:06 0:08
    Local Custom Doc Second Open 0:05 0:06
    Network Custom Editor First Start 3:07 3:54
    Network Custom Doc First Open 2:37 2:40
    Network Custom Editor Second Start 1:33 1:28
    Network Custom Doc Second Open 2:30 2:49
    I can't imagine anyone wants the raw data ... but I've got that for
    posterity's sake.
    Testing Process:
    1) Reboot.
    2) In no particular order:
    a) Connect to VPN.
    b) Start Task Manager.
    c) Start TextPad.
    d) Open notes file in TextPad.
    e) Start Windows' Date and Time Properties.
    f) Wait until CPU idles.
    3) Begin tests.
    4) Type notes during start attempts.
    5) Switch a little between various Task Manager views.
    6) TextPad save notes after start or load complete.
    Repeat 1 - 6 for each test.
    Note: I cussed like a banshee somewhere in there after I copied all my
    network shortcuts to my network homedrive, disconnected from my homedrive,
    and then could not find it in Recent or Network Neighborhood after running
    all the tests. Doh! Locked the keys in the car, the combination in the safe.
    Fortunately corporate support was able to retrieve it somehow. (I eventually
    also found it in my registry, because, you know, I kept looking just so I'd
    know if I'd've survived on my own 😉
    Paul Nagai
    Apr 5, 2011 4:58 PM UTC
    Hi Paul,
    I did not try a later JDK/JRE as I don't believe it was fixed when I was troubleshooting this. We were able to handle user performance issues by moving zip files and/or disabling Windows zip integration.
    -Mark
    Jun 29, 2011 1:55 AM UTC
    Hi Adrion,
    Could you please explain how to use
    sh atitrace &; set debug==extwin;set debug=9.1
    sh atitrace &; set debug==extwin;set debug=3.1
    and what is the use of it? how is it different from debug=3.27
    Thanks and Regards,
    Suresh
