Feb 17, 2023 3:10 PM UTC
Arbortext Editor, Styler, Publishing Engine 8.2.0.1 have released!
This release supports the ability to run Editor or Styler 8.1.x.x and 8.2.0.1 on the same system.
It also contains bug fixes.
8.2.0.0 will no longer be available for download.
PTC recommends that customers who have previously downloaded 8.2.0.0 should uninstall 8.2.0.0 and move to 8.2.0.1.
Mar 2, 2023 2:29 PM UTC
Hi - Can you pls mention which SPR/bug is fixed other then having ability to run 8.1.x.x and 8.2.0.1 on the same system.
regards,
Gaurav
plutsky15-MoonstoneAuthor
Mar 3, 2023 1:05 PM UTC
It was an issue with the Document Type Viewer (Tools->Document Type Viewer).  However we are concerned that it affects other areas as well, so we recommend customers to move to 8.2.0.1.
Patti
