7-Bedrock
Dec 4, 2025 7:50 PM UTC
Arbortext Editor/Styler/Publishing Engine 8.3.2.0 has Released
December 3, 2025
Key Highlights
  • DITA Map Reviewer: Streamlined review workflow with DITA Map tree for validating structure and completeness.
  • QuickTags Enhancements:
    • Most Recently Used (MRU) tag list at cursor location.
    • Multi-column QuickTags menu for faster tag discovery.
  • Docked Panels:
    • Modify Attributes panel for quick attribute edits.
    • Insert Markup panel for easier tag insertion and learning.
  • WTPart Attribute Support:
    • Include WTPart attributes in published outputs.
    • Support for translated attribute values in output.
  • Customer-Requested Improvements:
    • Save inline applicability strings.
    • “Check out Revised Objects” option after revision.
    • Automatic local cache cleanup preference.
  • Setup & Configuration Updates:
    • Streamlined PTC Server connection setup.
    • Easier transaction archive collection.
    • Improved font recognition.
    • Updated CreoView (v12) and IsoView (v7.4.4).
    • Show active burst rule in Session Panel
  • Stylesheet Object Listings
  • Group Elements by namespace
    • Sort UFEs, SFEs and Document Elements under their own tree nodes
    • Namespaced elements (MathML, SVG) grouped under their own nodes
  • Filter objects with search string
    • All groups can be filtered (elements, property sets, functions etc)
    • ‘Starts with’ and ‘contains’ searches to find objects quickly
Documentation
Download
TIP! Visit the Product Release Announcements on the hub for information about other recent PTC Software releases (Internal Site)
Best Regards,
Brent L. Kelly
Arbortext Product Manager, Fellow
SLM Arbortext Business Unit
brkelly@ptc.com
Stay connected:  Arbortext Homepage, Community, LinkedIn, YouTube
bfriesen
18-Opal
Dec 4, 2025 8:06 PM UTC
Very nice. Thanks for all the info Brent.
Bryon
11-Garnet
Dec 11, 2025 8:25 PM UTC
Where can I find further information regarding the automatic local cache cleanup preference?
7-Bedrock
Dec 12, 2025 7:00 AM UTC
I think you might want to visit below section of Help Center guide.
https://support.ptc.com/help/arbortext/r8.3.2.0/en/#page/admin/cms/help6420.html
Topic : DeleteLocalContentOnRemoveFromWorkspace
