Arbortext PE 8.0.2.0 PDF composition Fails
- 4 replies
- 3877 views
- Translate All
Arbortext Publishing Engine 8.0.2.0 , Publish to PDF fails with below error
APP did not produce an output file
<Message> Error return '0' from PDF generator. </Message>
<Trace> java.lang.Exception: Error return '0' from PDF generator. at com.arbortext.e3c.PdfServerExtension.doCompose(PdfServerExtension.java:303) at com.arbortext.e3c.ServerComposer.doCompose(ServerComposer.java:597) at com.arbortext.e3c.Application.doPost(Application.java:173) at com.arbortext.e3.subprocess.EpicE3AppContext.doJava(EpicE3AppContext.java:349) at com.arbortext.e3.subprocess.EpicE3AppContext.handleE3AppRequest(EpicE3AppContext.java:897) at com.arbortext.e3.subprocess.EpicE3AppContext.doRequest(EpicE3AppContext.java:667) </Trace>
Attached debug log. Any help is appreciated.
