Mar 8, 2018 5:21 PM UTC
Arbortext: Publishing DITA with XSL without resolving document(s)
I'm wanting to process a bookmap and all its children (well, descendants really, but I'm stuck on even the children) just running a simple XSL transformation against the bookmap and each DITA file href'ed in the bookmap. I can't figure out how to prevent the DITA getting resolved into a resolved document. Am I missing something really obvious or is this actually "hard" to do?
I can obviously use a command line tool (or, GASP, another XML editor), but I'd like to keep the author experience in a familiar tool if at all possible.
Seems like it should be easy so I'm hoping I'm missing some obvious switch ...
I am:
Arbortext Editor and Publishing Engine 7.0 m040.
Publish>Using XSL>mystylesheet.xsl.
Thanks.
    pnagai1-VisitorAuthor
    Mar 9, 2018 8:26 PM UTC
    Ignore (or if you know how, delete) this post. I reposted over in the Arbortext area which is probably most appropriate for this content.
