3-Newcomer
Oct 4, 2024 10:03 AM UTC
Arbortext publishing engine 8.2.3 with axis2 in order to use PEWebService
Hi all! we need to use APE 8.2.3 with PE SOAP but is deprecated from version 8.1
i have integrated axis2 in our apache 9, but something is wrong, i cannot get the pdf, the APE do not generate it and i didn't have any response.
now i am using:
http://MYSERVER:8080/axis2/services/PEWebService
instead before with version 8.0 i am using:
http://MYSERVER:8080/PEaxis2/services/PEWebService
i get the same info, i see the wsdl 🙂 ... what i have done is to copy the PeWebService.aar from the version 8 to the version8.2.3 (i don't know if is correct)
Summarizing... can someone explain me or show a guide in order to have enable the PE SOAP in the version arbortext publishing engine 8.2.3 ...  due my application needs it....
thanks a lot.
david,
Catalina
Community Manager
Oct 11, 2024 1:41 PM UTC
Hi @DD_9798060,
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
