bfriesen
18-Opal
Mar 18, 2019 5:51 PM UTC
Arbortext Publishing Engine cannot see profiles when publsihing
When publishing with APE, if any profile is selected, we get red page published with no content. It seems that it cannot see our pcf files. Has anyone else seen this.
Bryon
Mar 18, 2019 8:43 PM UTC
In cases like this it is worth checking that the custom folders match between your Editor desktops and the PE server. If you haven't already done so, be sure to copy over the .pcf file to the server. On the server itself you can use the PE Interactive application to help debug.
bfriesen
bfriesen18-OpalAuthor
18-Opal
Mar 19, 2019 3:09 PM UTC
Thanks Gareth, I did think about the mismatch issue and double checked files that the files are identical.
Should my custom application folder be located in the C:\Program Files\PTC\Arbortext PE\application\ folder or should it be located in C:\Program Files\PTC\Arbortext PE\custom? I tried using the APTCUSTOM but PE would never find my application.
Bryon
Mar 19, 2019 9:07 PM UTC
You should definitely be using APTCUSTOM, failing that it is the "custom" folder but that is very much not recommended. Most likely reason APTCUSTOM isn't being seen by PE is that you have set this environment variable for a user account, whereas PE usually run as the SYSTEM account. You need to set the environment variable at the system level.
