Arbortext S1000D Installation
I want to know if Arbortext S1000D is compatible with SQL Server now or if it is still just Oracle. I was told that the latest release was going to be compatible with SQL Server but I can not find any documentation on it.
Help please. We have to install our instance that we purchased and are running out of time.
Hi Jamie,
In an attachment you can find some of the reference documents:
1. "Installing Arbortext for Aerospace & Defense 4.4 F000/M070".
2. "Arbortext A&D S1000D/S2000M Software Compatibility Matrices".
More documents can be found in "Reference Documents" on PTC's site: https://www.ptc.com/appserver/cs/doc/refdoc.jsp
jstarling1-VisitorAuthor
I looked at both of these today and there is nothing in there about SQL Server other than SQL Plus which is not the same.
You can try to open a new case for PTC's tech support: https://www.ptc.com/appserver/cs/case/case_logger.jsp
