Architect DTD Editor - Unable to Write DTD when Saving
I am attempting to modify and save a DTD within the Arbortext Architect DTD Editor6.0 on Windows 7 (64 bit).
However, whenever I try and save the DTD, I get "ERROR: could not write DTD file C:\***.dtd".
I have checked permissions on this folder and even tried moving and writing to it on a different drive, but each time I get the same error.
Has anyone else encountered this ?
All works OK on previous versions.
Andy
    Jason,
    Yes, in Win7 there is a difference between the 'Administrator' user account and named user accounts with 'administrator' rights. The Administrator user account is often hidden in the user account list.
    Hi Lynn,
    In my case the doctype is in a 'development' area, I'm the only one with access to it. There is the possibility that the file is seen as 'in use' following a previous open and some sort of failure on the close. The server has been restarted two or three times in the history of this problem (after power outages) so I would have thought a faulty close should have been cleaned up.
    David
    aleslie1-VisitorAuthor
    Hi David,
    I just get "Validation failed".
    Agree - running as administrator makes no difference.
    It's on the local PC but I have attempted trying it from my server but still no difference.
    Andy
    Andrew Leslie
    Director
    Structured Information Limited
    Beer, East Devon, UK, EX12 3LU
    Hello Andy,
    Here are a few thoughts that come to mind, in no particular order...
    - Is the validation failing on just one DTD or all DTDs?
    - XML or SGML?
    - Does AA correctly determine that the DTD is either XML or SGML?
    - Are you able to parse the DTD with another parser such as XMLSpy?
    - In Options/Preferences/Advanced is 'validationmode' set to either 'all' or 'dtd'?
    Cheers,
    David
    David S. Taylor
    Project Manager, Production and Marketing
    Codes and Evaluations | NRC Construction Portfolio
    National Research Council Canada
    Building M-23A, Room 239 | 1200 Montreal Road | Ottawa, ON | K1A 0R6
    Telephone: +1.613.990.2731 | Fax: +1.613.952.4040
    David.S.Taylor@nrc-cnrc.gc.ca<">mailto:David.S.Taylor@nrc-cnrc.gc.ca>
