Jul 5, 2016 5:45 PM UTC
Assertion Failed: size < TXF_MARK, file ../src/stortxt.cpp, line 89
Composing with xsl-fo gives Assertion failed: size < TXF_MARK, file ..\src\stortxt.cpp, line 89 followed by FATAL ERROR: Operation terminate.
Using Arbortext Editor 6.0 M070 on WIndows 7. I have a lot of inschlvl attributes. Composes when I remove them. Narrowed it to one file. That file composes by itself. Looks like this may be some sort of Arbortext limitation. Is there any variable I can set to up this limitation, if that is what it is.
Has anyone anyone seen this?
LB
    Jul 6, 2016 3:29 PM UTC
    There was a fix for this issue in the 6.1 M040 release.
    The 6.0 release does not and will not receive this fix as the 6.0 release is on sustained support. (No further fixes or upgrades.)
