Jan 20, 2011 3:47 PM UTC
attaching a Range to an empty DocumentFragment in Javascript
Hello Adepters,
I'm trying to convert an arbitrary string of markup into a DocumentFragment. The only method I know of to do that is insertParsedString(), with is a method on Range objects.
Unfortunately, I haven't been able to figure out how to attach a range to a fragment and make it work right. I've tried a few variations on the following theme:
var d = Application.activeDocument;
var f = d.createDocumentFragment();
var r = f.getOwnerDocument().createRange();
r.selectNodeContents(f);
r.insertParsedString("test");
Doing that, I get a "paste would make in the pasted region out of context." I've also tried using the setStart() and setEnd() methods on range to no avail.
Does anyone have any advice?
James
    18-Opal
    Jan 20, 2011 4:16 PM UTC
    Hi James--
    Try this formulation:
    var doc = Application.activeDocument;
    var frag = doc.createDocumentFragment();
    var r = frag.ownerDocument.createRange();
    r.setStart(frag,0);
    r.setEnd(frag,0);
    r.insertParsedString("bar");
    Seems to work for me.
    --Clay
    jsulak1-VisitorAuthor
    Jan 20, 2011 5:04 PM UTC
    Hmm. Thanks, Clay. I tried that before, but it turns out that it works in 5.4 but doesn't in 5.3, which was what I was originally testing in. That's annoying, but there's probably not a lot I can do about it other than upgrade.
    James
    Jan 25, 2011 3:46 AM UTC
    Just to follow up...
    After further investigation, this does work in 5.3, despite the exception being thrown. So this (kludge) works:
    r.setStart(frag,0);
    r.setEnd(frag,0);
    try {
    } catch(e) {
    // swallow exception
    -James
