"Attempt to use non-existent character (61527)"
Does anyone know where I can find out what character this error message refers to?
Attempt to use non-existent character (61527) in font "Arial"
> - looking for slant=regular, weight=medium (500)
> - no substitute character exists in font "Arial Unicode MS"
Thanks!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
    Ooops. I lied. We stopped suppressing ligatures at some point. Brain fail.
    When we did suppress it, we used this code an ACL in Editor's custom/init
    folder:
    $ENV["APTLIGATURESENABLED"]="no"
    OR in a batch file used to start Editor like this:
    set APTLIGATURESENABLED=no
    We may have also set it from PE's custom folder but I can't tell for sure
    anymore.
    We had problems with ligatures with Arbortext 6 and Windows 7. It seemed that Arbortext 6 was still using XP font definitions. I hope the description and solution below help.
    Examining the Arial [1] and Times New Roman [2] fonts shipped with Win7, we see that "Latin Small Ligature Fi" is located a code point U+FB01 and "Latin Small Ligature Fl" is located a code point U+FB02. Examining the same TTFs [3] we find these glyphs located at these standard points but also at U+F001 and U+F002 respectively, which is a private use area of the Unicode space. On the Win7 verisons of these fonts there is no glyph defined at the U+F001 and U+F002 code points.
    [1] Font name: Arial, Version: Version 5.06, OpenType Layout, Digitally Signed, TrueType Outlines: arial.ttf, ariali.ttf, arialbd.ttf, arialbi.ttf
    [2] Font name: Times New Roman, Version: Version 5.07, OpenType Layout, Digitally Signed, TrueType Outlines: times.ttf, timesi.ttf, timesbd.ttf, timesbi.ttf
    [3] OpenType Font, Digitally Signed, TrueType Outlines, Typeface name: Arial, File size: 359 KB, Version: Version 3.00, Typeface (c) The Monotype Corporation
    [4] OpenType Font, Digitally Signed, TrueType Outlines, Typeface name: Times New Roman, File size: 400 KB, Version: Version 3.00, Typeface (c) The Monotype Corporation
    You can also disable ligatures in AE 5.4 in the FOSI:
    <docdesc>
    <lettersp allowligs="0">
    </docdesc>
    or in a .tmx file for the doctype:
    \ligaturesenabled=0
    I haven't used AE 6 yet, perhaps someone else can say whether these are still usable.
    David
    David S. Taylor
    Project Manager, Structured Information
    Production and Marketing | Building Regulations | NRC Construction
    Building M-23A, Room 114 | 1200 Montreal Road | Ottawa, ON | K1A 0R6
    Telephone: 613-990-2731 | Fax: 613-952-4040
    David.S.Taylor@nrc-cnrc.gc.ca<">mailto:David.S.Taylor@nrc-cnrc.gc.ca>
    Disabling ligatures in general was a solution we considered, but we had too many existing files that would make this impractical. We had to fix the fonts.
    FYI - pltotf.exe and tftopl.exe are located in ...PTC\Arbortext Editor\bin\x86
