Nov 19, 2019 8:54 PM UTC
Batch processing - removing entities from xml files and flatten the files
Here is my script
set Arbortext="C:\Program Files (X86) \PTC\Arbortext Editor\bin\x86\editor.exe"
for %%i in (*.xml) do (
"C:\Program Files (X86) \PTC\Arbortext Editor\bin\x86\editor.exe" -c -b "doc_flatten all undeclare" %%i
I cant get the changes to save to each file.  Any help appreciated.
Nov 20, 2019 1:27 PM UTC
In this case you should use the doc_save command and in fact this takes a parameter to allow it to flatten entities too. So, you may either call doc_flatten and doc_save or only doc_save. http://support.ptc.com/help/arbortext/r8.0.0.0/en/index.html#page/Program/acl_ref/help14996.html
Example code:
doc_save(0, 0x2C000)
Nov 25, 2019 12:24 PM UTC
How do you call 2 functions in same batch process?  if you could provide 2 samples.  one with doc_save alone and one with both.  Thanks.
Nov 25, 2019 2:16 PM UTC
If you use the all-in-one doc_save method then you don't need to worry about double function calls. The following is untested but should in theory work:
"C:\Program Files (X86) \PTC\Arbortext Editor\bin\x86\editor.exe" -c -b "doc_save(0, 0x2C000)" %%i
