7-Bedrock
Feb 24, 2022 2:42 PM UTC
Bezier Short Handles
Hi Gang,
I maybe missing something so please forgive me if this has been answered. When drawing a Bezier path and coming back to add handles to use to smooth the curve I find that some of the handles are very short and impossible to select to lengthen. Is there a way of controlling the length of the Bezier handles without selecting them, or am I just stuck?
Feb 25, 2022 9:40 AM UTC
They changed the defaults to show the value graphs, which for position don't have handles, since one would edit the path in the comp Split the properties or switch to the temporal graph.
khoward7-BedrockAuthor
7-Bedrock
Mar 8, 2022 3:08 PM UTC
Thanks for the reply. That was a little different than what I was looking for, but good information.
Keith
7-Bedrock
Mar 8, 2022 3:07 PM UTC
Here is what I have done on this. If I go in and right mouse click on the Bezier and select "Element Info" I can go through and remove the handles, then close out of the edit. Then reselect the Bezier and add the handles back in, when I do this it usually add the handles back in with enough length to smooth out the Bezier.
