blown out paths
I was playing with code and changing paths, It was complaining about being
in a loop, and would not break, so I used the task manager to end it. Now,
Arbortext Editor will not open. I get [A17120] Assertion failed: dt, file
../src/dt.cpp, line 1925
I know the paths must be blown out, how do I fix it? Some command line
thing?
Feeling stupid.
d
    18-Opal
    February 14, 2012
    Did you try starting up with no customizations?
    If that doesn't work, try rebooting and see if that helps. (Try both
    with and without customizations after reboot.)
    Can you roll your codebase back to a previous version? (You *are* using
    source control, right? 😉
    If that still doesn't work, then you might need to reinstall...
    Clay Helberg
    Senior Consultant
    TerraXML
    I changed the default doctypes instead of the custom/doctypes. I know I
    should not respond to IM when I am trying to code. I feel stupid, but it is
    all better.
    d
