Oct 21, 2014 5:23 AM UTC
Booktitle and frontmatter appear twice in output PDF file
I have been confused for a few days. If I publish a bookmap into PDF with my self-defined style-sheet, the book-title and the front-matter will appear twice! They will appear at the start of the book (It is correct), and appear again at end of book (It is not what I expect).
However, if I publish the bookmap file with default style-sheet, the result is correct—they just appear at the start. I try to adjust the style sheet many times. It seems I didn’t know where to solve it.
I don’t know how to control it – how to remove them from the end of the books. Can somebody help to answer it?
rdiazAnswer
Oct 21, 2014 6:29 PM UTC
Hi Kelvin,
You may want to start by comparing the two stylesheets on the top-level element, looking at the gentext tab.
You can also check out the pageset gentext, in case it's defined there.
I also notice you mention it's a bookmap. Are you using 'Edit Resolved Document' to make the changes, and see how they work out?
rdiaz5-Regular MemberAnswer
Hi Kelvin,
Oct 22, 2014 3:17 AM UTC
Hi Rafael,
The issue has been solved with your advice. I used ''Edit Resolved Document'' and found an element flattenedmap. It is the hidden element cause twice appearance. I added flattenedmap element in style sheet and set it as 'hidden' sytle, the problem was then fixed.
Thanks for help!
