Browser Version of ArborText
The subject of my message is little different but my question is same as it was raised earlier in the below link in 2008.
http://portal.ptcuser.org/p/fo/st/topic=21&post=70228#p70228
Currently we use ArborText for XML editing but our business requires a web-based editor that can talk to our CMS so people outside of our regular editors can make changes to the content using a web browser. We are so accustomed to ArborText and because of this requirement we are pushed to see if any other editor in the market is capable of addressing this requirment.
Can you guide if Arbortext is available/customizable for a web-based editor? If so is there a demo or sample website that I can take look.
Karthik
    18-Opal
    May 6, 2010
    Hi Karthik-
    The latest version of Arbortext Editor (5.4) has an ActiveX control for
    embedding Editor in other applications, including a web page. The
    control within the page has most of the functionality of the full Editor
    installation.
    The ActiveX control has to be installed on the end user's machine to
    make this work. You can facilitate this using the Arbortext Deployment
    Kit. You will also probably need a concurrent license server set up to
    provide licensing for the casual users.
    If you are interested in checking this out, look in the 5.4 help center
    for Embedded ActiveX control. IIRC, the Deployment Kit is a separate
    download from the Editor installer, which you'll need to get from the
    PTC support web site, but doesn't require a separate license.
    --Clay
    Thanks Clay. This helps. I will check this out.
    Karthik
