Jan 13, 2011 3:44 AM UTC
Bug??
I've been testing an ACL script that uses the function inside_tag(). It
seems to have a bug. If I test for an element name that has a 'dot' in the
name (e.g., <dtd.frag>) it will not recognize when it is inside the tag.
I've tested this with a couple of different element names both in the script
and from the command line and get the same result which is a failure.
Has anyone else found this to be true? And if so does anyone have a work
around.
Many thanks.
Lynn
    18-Opal
    Jan 13, 2011 3:56 AM UTC
    Hi Lynn-
    What version are you using? I just tried this with 5.4 M050 and it seems
    to work OK. I did a freeform XML document with <document.root> as the
    root element and <para.graph> as a child. With the cursor inside the
    <para.graph> element, inside_tag() returns 1 for both "document.root"
    and "para.graph".
    As a workaround, the help for inside_tag() says "If you have applied an
    alias map to the document, tagname can be an alias, as well as a real
    name." So maybe you could define an alias to your <x.y> element name and
    test for that?
    --Clay
    Jan 13, 2011 3:53 PM UTC
    LynnHales1-VisitorAuthor
    Jan 13, 2011 6:47 PM UTC
    Paul you know me too well. 😄
    That was it. When I delimited the element name, it works as advertised.
    Lynn
    ---- "Grosso wrote:
