Mar 8, 2024 7:30 PM UTC
Callback on DELETE key
I need to add a callback on when the DELETE key is pressed.  I don't need to change the behavior of the key pressing but only to detect it and being able to run a function additionally to the normal process.
Thanks for your time.
PartnerAnswer
Mar 18, 2024 4:01 PM UTC
Good afternoon, thanks for taking the time to answer me back.  I ended up using the following code:
doc_add_callback(current_doc(), 'delete', 'triggerDelete');
function triggerDelete(doc, op){
	local tickEvent;
	if($op == 1 && numerotationHelper::insertionInProgress == 0){
		# callback are always called twice
		# https://support.ptc.com/help/arbortext/r8.1.0.0/en/index.html#page/Program/acl_ref/help148-517.html
		numerotationHelper::lastDeletePressed = javascript('d = Date.now();d.toString();');
		local selectedElement = selected_element();
		if(index(selectedElement, "-1")>0){
			numerotationHelper::lastObjectParentDeleted = "";
			numerotationHelper::lastObjectDeleted = "";
		else{
			numerotationHelper::lastObjectParentDeleted = oid_parent($selectedElement);
			numerotationHelper::lastObjectDeleted = oid_name($selectedElement);
Once again, thank you !
Community Moderator
Mar 14, 2024 5:18 PM UTC
Hi gbélanger,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
Partner14-AlexandriteAuthorAnswer
	local tickEvent;
		else{
18-Opal
Mar 14, 2024 7:10 PM UTC
You can do this using the map command in ACL, something like this:
function myDeleteExtras() {
 # do whatever extra stuff you need here...
 EditDelete; # this executes the normal delete operation
map Delete {myDeleteExtras()}
