Jan 30, 2016 5:40 AM UTC
Can any one suggest how to do a program
Can any one suggest how to do a program or set of instruction (like macro) which will show the errors in the authoring file (content) on running the program.
Eg: The statement should be
Correct: “put the unit in position”
Wrong:  “put the unit in its position”
If we use in its position in the authoring, it should show error
Jan 31, 2016 11:38 PM UTC
For the example you give, the code is obviously trivial. Are you asking for a generic grammer checker? Simplified english validation? How deep do you need to go? You should consider commercial plugins if you have anything more than the most simple needs.
Feb 4, 2016 5:34 PM UTC
thanks Gareth,
Its not a grammar check. In my work there are a lot of standard statements and set of value which is common for all tasks which i do. Some times by mistake I used to give wrong values. To avoid such mistakes I need to create a checker
eg: 1.torque so and so, refer to document "111112222" (doc no)
the torquing should be done by referring the document"111112222". Instead by mistake we will write as "111112223" which is wrong and that should be identified while checking.@
Feb 5, 2016 12:23 AM UTC
Assuming you are on a recent version of Arbortext (6.0 or later), the simplest method to achieve this is to use the built-in Schematron support. Define a Schematron rule set that reports on the errors you need to pick up. Add this Schematron to your doctype. The Schematron errors will then be reported by Arbortext during validation.
Feb 2, 2016 12:51 PM UTC
Another option would be to use entities.
One can set up entities for common string sequences, phrases, paragraphs, etc.
Feb 4, 2016 5:37 PM UTC
thanks Tim,
the torquing should be done by referring the document"111112222". Instead by mistake we will write as "111112223" which is wrong and that should be identified while checking. can u plz guide me how to do that
Feb 22, 2016 1:11 PM UTC
Rather than having to key these standard phrases, could you have the style sheet insert the data via generated text, by testing a given specific attribute value in the root tag, and a given tag and/or set of attribute settings?
The attribute in the root tag would identify the document.
The tag testing would indicate where to place the text and the attribute(s) values would specify the text or phrase to be inserted.
This way users would only need to insert the tag, and set certain attribute values.
