6-Contributor
Apr 4, 2024 12:01 PM UTC
can't preview or export PDFs because the PTC Arbortext Publishing Engine isn't configured.
Hello everybody, can somebody help me? I'm using Arbortext 8.2 but can't preview or export PDFs because the PTC Arbortext Publishing Engine isn't configured. Somebody can provide me steps on how to fix this error.
AlexiaAnswer
Apr 4, 2024 12:08 PM UTC
The first question is 'do you have a Publishing Engine' License?
If you only have an Arbortext Editor license you will not be able to publish content, you will only be able to Edit content.
There are many Knowledge Base articles available on the main PTC Support Site that will assist you or the Help Center topics.
You can check your license.txt file which will tell you what products you have licensed.
I hope this is of help
Alexia
Alexia15-MoonstoneAnswer
Alexia
6-Contributor
Apr 4, 2024 1:36 PM UTC
Hello, Alexia. Thank you for your feedback. Currently, we only have Arbortext Editor, Arbortext Print Composer, and Arbortext with Styler License. Is there any missing license why we can't preview or export PDF or just the Publishing Engine License is missing?
bfriesen
18-Opal
Apr 4, 2024 1:44 PM UTC
Editor will use the print composer license to publish and styler has publishing built in. When you install editor you need to ensure that you have selected to install the print composer option. Can you publish from styler?
Bryon
